Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Ilogic code tweak on creating viewreps
0 REPLIES 0
Message 1 of 1
DClunie1
209 Views, 0 Replies
Hi All
I am after some help converting code to do something different on how this runs.
Code attached searches a custom property we have embedded within our Inventor oarts and if found creates a viewe rep and locks down that view.
The code workd great and does the job but i need the browsr node name to be different as it copies file name and places it there for its name.And I would like the code to work exactly the same but to give viewrep the name the Description of the part instead.
Appreciated if someone can show me the teak i need to enables this to work.
SyntaxEditor Code Snippet
Sub Main
Dim propertyName As String = "DESC2"
Dim propertyValue As String = "BEVEL/"
Dim propertyValue2 as String = "ROUT/WRAP/"
Dim propertyValue3 as String = "ROUT/"
Dim propertyValue4 as String = "NOTCH/"
Dim propertyValue5 as String = "HP/"
Dim propertyValue6 as String = "HINGE/"
Dim propertyValue7 as String = "SLOT/"
Dim propertyValue8 as String = "ROUT/WRAP/HINGE/"
Dim oDoc As Inventor.AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
Dim oCompDef As Inventor.ComponentDefinition
    oCompDef = oDoc.ComponentDefinition
'define view rep
Dim oViewRep As DesignViewRepresentation
'define an arraylist to hold the list of  view rep names
Dim NameList As New ArrayList()
'Look at the view reps in the assembly
For Each oViewRep In oCompDef.RepresentationsManager.DesignViewRepresentations
    'set the list of names to the array list
    NameList.add(oViewRep.Name)
Next
Dim oCompOcc as ComponentOccurrence
Dim oCompOcc2 as ComponentOccurrence
    For Each oCompOcc In oCompDef.Occurrences
        If oCompOcc.SubOccurrences.Count = 0 Then
        Try
            OCompOccName = oCompOcc.Name
            If iProperties.Value(oCompOccName ,"Custom",propertyName ) = propertyValue _
            Or iProperties.Value(oCompOccName ,"Custom",propertyName ) = propertyValue2 _
            Or iProperties.Value(oCompOccName ,"Custom",propertyName ) = propertyValue3 _
            Or iProperties.Value(oCompOccName ,"Custom",propertyName ) = propertyValue4 _
            Or iProperties.Value(oCompOccName ,"Custom",propertyName ) = propertyValue5 _
            Or iProperties.Value(oCompOccName ,"Custom",propertyName ) = propertyValue6 _
            Or iProperties.Value(oCompOccName ,"Custom",propertyName ) = propertyValue7 _
            Or iProperties.Value(oCompOccName ,"Custom",propertyName ) = propertyValue8 Then
                'check for a Test view rep and create it if not found
                If Not NameList.Contains(OCompOccName) Then
                    'create Test view rep
                    oViewRep = oCompDef.RepresentationsManager.DesignViewRepresentations.Add(OCompOccName)
                    oViewRep.ShowAll
                    oViewRep.Activate
                Else
                    'reference existing View Rep
                    oViewRep = oCompDef.RepresentationsManager.DesignViewRepresentations.Item(OCompOccName)
                    oViewRep.Activate
                    oViewRep.Locked = False
                    oViewRep.ShowAll
                For Each oCompOcc2 In oCompDef.Occurrences
                    Dim oCompOcc2Name As String
                    oCompOcc2Name = oCompOcc2.Name
                    If oCompOcc2.SubOccurrences.Count = 0 Then
                        If oCompOcc2Name = oCompOccName Then
                        oCompOcc2.Visible = True
                        'MessageBox.Show(oCompOcc2Name, "Visible")
                        ThisApplication.ActiveView.Update()
                        Else
                        oCompOcc2.Visible = False
                        'MessageBox.Show(oCompOcc2Name, "Not Visible")
                    Else
                        processSubOcc(oCompOcc2, oCompOccName)
                Next
                'lock view rep
                oViewRep.Locked = True
                'messagebox.Show("View locked", "Done")
        Catch ex As exception
        End Try
        Else
        processAllSubOcc(oCompDef, oCompOcc, NameList, propertyName, propertyValue, propertyValue2, propertyValue3, propertyValue4, propertyValue5, propertyValue6, propertyValue7, propertyValue8 )
    Next
    'Master
oViewRep = oCompDef.RepresentationsManager.DesignViewRepresentations.Item("Default")
oViewRep.Activate
End Sub
' This function is called for processing sub assembly. It is called recursively' to iterate through the entire assembly tree.
 Sub processAllSubOcc(ByVal oCompDef as ComponentDefinition, ByVal oCompOcc As ComponentOccurrence, ByVal NameList As ArrayList, ByRef propertyName As String,ByRef propertyValue As String, ByRef propertyValue2 as String,ByRef propertyValue3 as String,ByRef propertyValue4 as String,ByRef propertyValue5 as String,ByRef propertyValue6 as String,ByRef propertyValue7 as String,ByRef propertyValue8 as String)
    Dim oSubCompOcc As ComponentOccurrence
    For Each oSubCompOcc In oCompOcc.SubOccurrences
        If oSubCompOcc.SubOccurrences.Count = 0 Then
        Try
            oSubCompOccName = oSubCompOcc.Name
            If iProperties.Value(oSubCompOccName ,"Custom",propertyName ) = propertyValue Or iProperties.Value(oSubCompOccName ,"Custom",propertyName ) = propertyValue2 Then
                If Not NameList.Contains(OSubCompOccName) Then
                    oViewRep = oCompDef.RepresentationsManager.DesignViewRepresentations.Add(OSubCompOccName)
                    oViewRep.ShowAll
                    oViewRep.Activate
                Else
                    oViewRep = oCompDef.RepresentationsManager.DesignViewRepresentations.Item(OSubCompOccName)
                    oViewRep.Activate
                    oViewRep.ShowAll
                        If oCompOcc2Name = oSubCompOccName Then
                        Else
                    Else
                        processSubOcc(oCompOcc2, oSubCompOccName)
                Next
                'lock view rep
        End Try
        Else
        processAllSubOcc(oCompDef, oCompOcc, NameList, propertyName, propertyValue, propertyValue2, propertyValue3, propertyValue4, propertyValue5, propertyValue6, propertyValue7, propertyValue8)
    Next
End Sub
 Sub processSubOcc(ByVal oCompOcc As ComponentOccurrence, _
                             ByRef oCompOccName As String)
        ' Check if it's child occurrence (leaf node)
        Dim oSubCompOccName As String
            If oSubCompOccName = oCompOccName Then
            oSubCompOcc.Visible = True
            Else
            oSubCompOcc.Visible = False
        Else
            processSubOcc(oSubCompOcc, oCompOccName)
    Next
End Sub
0 REPLIES 0
