Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Ilogic code to trigger rule in child component
1 REPLY 1
dave
617 Views, 1 Reply
I'm trying to create a rule in ilogic that would search through all child components (looking for both .ipt and .iam file types) looking for an ilogic rule within each child component with a particular name, and running that rule if it is found. Any ideas as to how I could do this?
Dave
1 REPLY 1
theo.bot
in reply to: dave
Dave,
try this:
Sub Main auto = iLogicVb.Automation
' Get the active assembly. Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument
' Get all of the referenced documents. Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments
' Iterate through the list of documents. Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
 Dim ruleName As String  ruleName = "Rule0"  Dim rule As Object  rule = auto.GetRule(oRefDoc, "Rule0")  If (rule Is Nothing) Then  'Call MsgBox("No rule named " & ruleName & " was found in the document.")  Else  MessageBox.Show(rule.Name, oRefdoc.displayname)    Dim i As Integer  i = auto.RunRuleDirect(rule)    End If
Next End Sub
