Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
ilogic code to display custom iproperty of selected part
3 REPLIES 3
DRLTKSE
2235 Views, 3 Replies
I would like to be able to select a part/sub-assembly in the assembly environent and then run a rule which displays an iproperty from the selected part/sub-assembly.
It's driving me crazy
Thanks for any help
3 REPLIES 3
DRLTKSE
in reply to: DRLTKSE
This is the code I am using. Everything works except for the last part. Even though I (think) I'm asking for the iproperties of the selected item I only get the iproperties of the top level assembly
SyntaxEditor Code Snippet
Dim oOccurrence As ComponentOccurrence
Try
  oOccurrence = ThisDoc.Document.SelectSet.Item(1)
Catch
  MessageBox.Show("Please select a component before running this rule.", "iLogic")
  Return
End Try
Dim doc As Document
Dim Prop As String
'Set the selected item
oOccurrence = ThisApplication.ActiveDocument.SelectSet.Item(1)
'get the selected item document occurrence name
doc = oOccurrence.Definition.Document
'get the property'Prop = iProperties.Value(doc:1, "Custom", "Stroke")
Prop = iProperties.Value(doc, "Project", "Part Number")
'Dispaly Property in Msg Box
MessageBox.Show(Prop)
LukeDavenport
Hi David,
I think this'll work. We need to refer to the occurrence name, and also be aware that if you have selected an occurrence in a sub-component, then the object you have selected will actually be a 'componentoccurrenceproxy' object, that you need to find the native componentoccurrence from to use the iLogic iProperties line afterwards.
Dim Prop As String
Try
Catch
  Return
End Try
If TypeOf oOccurrence Is ComponentOccurrenceProxy Then
    Prop = iProperties.Value(oOccurrence.NativeObject.Name, "Project", "Part Number")
Else
    Prop = iProperties.Value(oOccurrence.Name, "Project", "Part Number")
End If
'Display Property in Msg Box
DRLTKSE
in reply to: LukeDavenport
Hi Luke,
As ever thanks for this solution!
David
