Hello!
Can someone help me with this? Looking for the ilogic code to place in the drawing rule to close *.ipt file that was recently open.
Thank you, Any help appreciated
ok. I found the solution.
Thank you.
Dim oPart As PartDocument oPart = ThisApplication.Documents.Open(filename, False) oPart.Close
how would you close an assembly file?
i figured it out. I was missing the extension for the file name i was trying to close.
SyntaxEditor Code Snippet
opendoc = ThisDoc.PathAndFileName()'saves doc path and file name doc = ThisApplication.Documents.Open(opendoc & ".iam")'saves 'doc' as the open application from 'opendoc' adding the extension '.iam' doc.Close 'closes the indicated document 'doc'
