iLogic code to change the flat pattern orientation.
2 REPLIES 2
ro01
1544 Views, 2 Replies
Is there a way to switch the flat pattern orientation using ilogic. Or is there a way to flip the Base face back and forth on a part, but setting up custom orientations and being able to switch between them using ilogic would be nice.
2 REPLIES 2
ro01
in reply to: ro01
I have done this in an iPart, but I don't know what the variable would be in iLogic.
philippe.leefsma
in reply to: ro01
There is no difference between using the API in VBA or from iLogic, you can take a look at the API Help files, multiple VBA samples are available there.
The FlatPattern.FlipBaseFace method seems to provide what you are looking for.
The following sample illustrates how to rotate the flat pattern, that feature was introduced in 2014:
Public Sub SheetMetalOrientFlat()
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    Dim smDef As SheetMetalComponentDefinition
    Set smDef = partDoc.ComponentDefinition
    If Not smDef.HasFlatPattern Then
        smDef.Unfold
    End If
    Dim orientation As FlatPatternOrientation
    Set orientation = smDef.FlatPattern.FlatPatternOrientations.ActiveFlatPatternOrientation.Copy("New Orientation")
    ' Find an linear edge that lies along the flattened plane.
    Dim flatEdge As Edge
    Dim tempEdge As Edge
    For Each tempEdge In smDef.FlatPattern.Body.Edges
        If tempEdge.GeometryType = kLineSegmentCurve Then
            If Abs(tempEdge.StartVertex.Point.Z - tempEdge.StopVertex.Point.Z) < 0.0001 Then
                Set flatEdge = tempEdge
                Exit For
            End If
        End If
    Next
    orientation.Activate
    orientation.AlignmentRotation.Expression = "30 deg"
    orientation.AlignmentAxis = flatEdge
End Sub
Hope that helps.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
