Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic code to call Raw material & Size in drawing from model values
3 REPLIES 3
ped20
911 Views, 3 Replies
 Hello Folks
Greetings from Kiran
Please find image attached, in this drawing template i am modelled a plate that is having this finish size
Please tell me how write a code in iproperteis Stock string to fetch length, width, thickness parameters
That in to this Raw material & Size box
Did you find this reply helpful ? If so, use the Mark Solutions! Accept as Solution or Give Kudos!Kudos - Thank you!
3 REPLIES 3
Jefkee
in reply to: ped20
There is no image attached?
Inventor 2013
Ktomberlin
in reply to: ped20
yudhistira
in reply to: ped20
first you make a new parameter:
xmin
xmax
ymin
ymax
zmin
zmax
length
width
thickness
all  new parameter type numeric
then in rules write this code:
Dim oBox As box
oBox = ThisDoc.Document.ComponentDefinition.SurfaceBodies.Item(1).RangeBox
xmin=oBox.MinPoint.X
xmax=obox.maxpoint.X
length=(xmax-xmin)*10
ymin=oBox.MinPoint.Y
ymax=obox.maxpoint.Y
width=(xmax-xmin)*10
zmin=oBox.MinPoint.Z
zmax=obox.maxpoint.Z
thickness=(xmax-xmin)*10
HBM Training Center | Indonesian Professional CAD/CAM/CAE Training and Certification Center
http://www.hbm-training.com/
If my solution can answer your question, please push
"Accept As Solution" button in below ....
