I'm looking for a way to change the size of a custom content center part via ilogic. I found a way to replace them on this forum but this is not ideal for, because that creates a new part every time i change the size of the part.
Any ideas?
You cannot edit a CC part through the UI either: http://forums.autodesk.com/t5/Autodesk-Inventor/Edit-Content-Center-Standard-parts/td-p/2688048
When you use "Change Size..." from the context menu on the CC part instance, that as well will create a new part document using the new parameters.
As mentioned in the above discussion your options of modifying a part without getting a new document created are: you could modify the part outside the CC folder and move it back or modify it through its iProperties.
I hope this helps.
Cheers,
This works great for me:
http://forums.autodesk.com/t5/Autodesk-Inventor/Changing-C-C-component-Automation/td-p/2736623
