Inventor Customization
Distinguished Contributor
art_turner
Message 1 of 5 (342 Views)
Ilogic Change Parameter in any Part that is not a component
342 Views, 4 Replies
10-01-2013 02:43 PM
can you tell what i want to do here. the commented code does not work.
i want to be able to open a part and change its size parameters before i open the assembly. this code will run as an external rule in a new empty file.
if i can do it without opening the part, that is even better.
'test can i open a part, change a param, then close part
Dim fname As String
fname ="C:\Workspace\my_prog\chan\F_BB_L.ipt"
Dim pDoc as PartDocument = ThisApplication.Documents.Open(fname,False)
pDoc  = ThisApplication.Documents.Open(fname)
' these are just attempts to find a syntax that works
' i need the method to change the parameter
 'param = pDoc.PartComponentDefinition.Parameter.Param("TKNS")
 'pdoc.parameter.Param("TKNS") = 8
pdoc.Save
pdoc.Close
Here you go:
Dim fName As String = "C:\Workspace\my_prog\chan\F_BB_L.ipt"
Dim pDoc as PartDocument = ThisApplication.Documents.Open(fName, False)
pDoc.ComponentDefinition.Parameters.Item("TKNS2").Value = 8
pDoc.Update
pDoc.Save
pDoc.Close
jdkriek
Message 2 of 5 (320 Views)
Re: Ilogic Change Parameter in any Part that is not a component
10-01-2013 08:37 PM in reply to: art_turner
Here you go:
pDoc.Update
pDoc.Save
pDoc.Close
Jonathan D. Kriek
Autodesk Inventor Certified Expert
Microsoft Certified Application Developer
_____________________________________________________
Did I help you? Please choose Accept as Solution or Kudos below
art_turner
Message 3 of 5 (306 Views)
10-02-2013 06:22 AM in reply to: jdkriek
thanks!
but,
gives result in cm,
the parameter is in inches.
8 / 0.39370 gives a result in inches, with errors in the 5th place,
what is the standard way to input 8"?
thanks again.
Valued Mentor
MegaJerk
Message 4 of 5 (287 Views)
10-03-2013 04:44 AM in reply to: art_turner
Perhaps multiplying it would fix the problem
pDoc.ComponentDefinition.Parameters.Item("TKNS2").​Value = (8*2.54)
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
art_turner
Message 5 of 5 (268 Views)
10-03-2013 06:50 PM in reply to: MegaJerk
here it is
pDoc.ComponentDefinition.Parameters.Item("TKNS").Expression = "8 in"
