Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic!! Change frame generator part
4 REPLIES 4
pauinch85
2286 Views, 4 Replies
Hi all!
I'm using ilogic rules to customize an assembly generated by content center of frame generator. I would like replace the parts on my assembly when I change an assembly parameter multivalue.
Is possible??
Thanks!
4 REPLIES 4
Carthik_Babu
in reply to: pauinch85
I am also looking for the same option...
I am doing standardization of frames. I need one frame assembly in common for all needs.
Looking for ilogic option to change the frame size.
Request you to kindly help
Carthik Babu
Babcock Borsig Softtech Private Ltd
Carthik Babu M.S, Asst Manager - Machine Building,
Gabriel India Ltd,Hosur, TN, INDIA
Email:carthik_ms@yahoo.co.in ,
https://grabcad.com/carthik-1/projects
"May all beings be happy" http://www.dhamma.org/
cean_au
in reply to: Carthik_Babu
yes it is possible.done that once.
cean
Carthik_Babu
in reply to: cean_au
Dear Sir,
Request you to provide what command i have to use in ilogic.
If i have to make it only by VB Plugin. Kindly ping me the VB codes for the same. I am in the process of learning VB coding to make Inventor Plugin. Request you to kindly help me regarding the same
Carthik
Carthik_Babu
check the link below
http://forums.autodesk.com/t5/Autodesk-Inventor/ilogic-part-insertion/td-p/3666746
http://www.youtube.com/watch?v=YgnHHQ0aRrY
