i have one external ilogic rule called Geo_creator who do some things when i lunch it. I like to have a simple VBA button in inventor who lunch this rule when i push it. What i have to write in Editor Visual Basic???
Solved by MjDeck. Go to Solution.
yes, simple vba code is way to go.
right click on panel, choose "use Customize commend..." then choose "macro"
Yes, thanks i know this but i have to do the vba code who luch the external ilogic rule. After that i can have this button, otherwise i have every time go over the external rule in iLogic browser, right click, and execute the rule.
try this
Are you using Inventor 2012? If so, you can create an iLogic form and add a button to the form. The button can run the rule.
