So, there are some users here that, when Invnetor crashes, they lose their ilogic browser (not a big deal) and ilogic configurator paths go back to default (is a big deal). Anyone ever experienced this or heard of it. If so any solutions?
Inventor 2013 SP2 Update 2
Thanks in advance!
I have not heard of this issue, but one thing you could try is back up the iLogic configuration file and restore it after a crash:
http://forums.autodesk.com/t5/Inventor-Customization/iLogic-Configuration-Where-Stored/td-p/2974774
Cheers,
This user config you are talking about. What all does it contain? We have a lot of users, all of which could and probably do have differnt settings.
You can simply open it up in e.g. notepad and see it for yourself 🙂
It should contain all the settings you see in the iLogic Configuration dialog in the UI.
I've had the browser get trashed after a crash, but never the actual iLogic paths.
So, nothing to add to the solution, but just more of a confirmation that not only you have experienced half of your problem 😉
