Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic BOM Structure Check from assembly drawing
1 REPLY 1
SoulAsasin
354 Views, 1 Reply
Hello all
Is it possible to go trough the part list in a drawing and check the BOM structure of every component in it?
I manage to go trough the part list, but i Don't know how to get the component of a specific row, to check it's Bom structure.
Anybody any info on this ?
Thank you.
Inventor 2012
Win 7 64-bit
Dell Precision T5400
Intel Xeon 2,5 GHz
8 Gb RAM
NVIDIA Quadro Fx 3700
1 REPLY 1
dkatz
in reply to: SoulAsasin
I think this might help you get there a little:
http://reinventinginventor.wordpress.com/2014/11/19/exporting-parts-lists-from-drawings-to-excel-wit...
Specifically, this part of the code grabs the referenced document for each row (I deleted the nonrelevant parts). FYI, You have to have a partslist selected before you run the program.
Dim drawDoc As Document
    Set drawDoc = ThisApplication.ActiveDocument
    If Not (TypeOf drawDoc Is DrawingDocument) Then
        MsgBox “A drawing must be active.”
        GoTo retry
    ‘ Make sure a parts list is selected.
    Dim partList As Object
    Set partList = drawDoc.SelectSet.Item(1)
    If Not (TypeOf partList Is PartsList) Then
        MsgBox “A parts list must be selected.”
        GoTo retry
    Dim drawBomRow As DrawingBOMRow
    For Each partListRow In partList.PartsListRows
        ‘ Get the thumbnail from the document associated with the current row.
        Set drawBomRow = partListRow.ReferencedRows.Item(1)
        Dim refDoc As Document
        Set refDoc = drawBomRow.BOMRow.ComponentDefinitions.Item(1).Document
        'Do whatever you're going to do with the component here.
    Next
I think this should work with iLogic.
Hope that helps,
Dave
