In the sample code is a sample ilogic Derived parts and assembly but if you read the sample it is for molding and subtracting this from that..
Not being the expert at ilogic I really cant make heads or tails of what to steal to make what I need.
I have lets call it a side body and it will be the left. when the user inserts this into an assembly a form will pop up so he can configure the side body. What I would like to add is a yes or no to create the right as a derived part.
I can create the yes and no option but I don't know where to begin to make the code to derive the part.
The location to put the derived part would be the local workspace but would need a way to name the file as well.
Any help would be great.. A book would be better. Or better sambles or snippits..
Solved by Curtis_Waguespack. Go to Solution.
how to do this for assembly? Do i make it Kpartassembly or something?
