I find it a pain to have to expand my Representations folder, expand my View folder, right click Master view then select 'All Visible' to turn the visibility of all my parts on again.
I'd like to write an iLogic rule that does exactly this and perhaps have it run by iTrigger or at least an stored as an external rule. I'll only be saving myself 1-2 clicks but every little helps.
Solved by pball. Go to Solution.
Solved by Owner2229. Go to Solution.
Hi, try this one:
trigger = iTrigger() Dim oDoc As Document oDoc = ThisDoc.Document Dim comp As ComponentOccurrencesEnumerator comp =oDoc.ComponentDefinition.Occurrences.AllLeafOccurrences Dim Occ As ComponentOccurrence For Each Occ In comp Occ.Visible = True Next
Hi Guys.
I found an issue while using All Visible rule. It doesn't work if in there is subassemble in assemble file. Is there any way to fix it ?
Perfect for getting a Marking Menu command to show all. Had to make it a macro though.
