Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic 2014: pattern suppression
1 REPLY 1
Allen_Hart
740 Views, 1 Reply
I have a main assembly containing a small sub-assembly, PA01, that is patterned.  There is an iLogic rule to control suppression of the pattern using the statement: Component.IsActive("PA01 Pattern 1:1") = False.
The pattern does suppress/unsuppress on queue, but i get a warning when suppressed that it failed to compute:
and if I force a rebuild outside of iLogic I get this:
Of course it cannot be edited because it is suppressed.  And when I set the rule to True all is well again.
It seems the elements are being suppressed but the pattern itself is not, therefore the warning.
So, the question is; is this the way patterns are supposed to act when suppressed?
Is there another way of writing the rule to prevent this warning?
Allen
1 REPLY 1
Allen_Hart
in reply to: Allen_Hart
Update: I've discovered the reason for the error is because the component pattern is feature based. IOW, it is based on a hole pattern in another part. I redefined the pattern to use parameters instead. Now there are no errors.
