Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic 2013 - Create Yes/No property type
3 REPLIES 3
2473 Views, 3 Replies
Dim propertyName1 As String = "Mortise"
Dim propertyName2 As String = "Cut Length"
customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
          prop = customPropertySet.Item(propertyName1)
		  prop = customPropertySet.Item(propertyName2)
Catch
      ' Assume error means not found
	  customPropertySet.Add("", propertyName1)
	  customPropertySet.Add("", propertyName2)
End Try
'output the custom iproperties and update the file
RuleParametersOutput()
InventorVb.DocumentUpdate()
'set iProperties
'iProperties.Value("Custom", "Mortise") = ""
'update file
iLogicVb.UpdateWhenDone = True
This code creates custom iProperties if the iProperty isn't found. I'd like to add another iProperty called "Resaw" with a Yes/No property type. Is there a way of doing this the way I have things started here?
Thanks very much
3 REPLIES 3
Curtis_Waguespack
Hi ToddVS,
Here is some code (and and example file) that should show how to do this.
Note that I ran into an issue with combining more than one custom iProperty in the Try/Catch, and have found it better to keep them seperate as I show in the example below.
I hope this helps.
Curtis
Dim propertyName1 As String = "Paint Code"
Dim propertyName2 As String = "Size"
Dim propertyName3 As String = "Galvanized"
Dim propertyName4 As String= "Completion Date"
'define custom prp[erty collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
'set property value
oProp = oCustomPropertySet.Item(propertyName1)
Catch
' Assume error means not found so create it
oCustomPropertySet.Add("", propertyName1)
End Try
Try
'look for property
oProp = oCustomPropertySet.Item(propertyName2)
Catch
oCustomPropertySet.Add("", propertyName2)
End Try
Try
'look for property
oProp = oCustomPropertySet.Item(propertyName3)
Catch
oCustomPropertySet.Add("", propertyName3)
End Try
Try
oProp = oCustomPropertySet.Item(propertyName4)
Catch
oCustomPropertySet.Add("", propertyName4)
End Try
Dim strPaintCode As String
Dim dblSize As Double
Dim blGalv As Boolean
Dim dtDate As Date
'get values from user
strPaintCode = InputBox("Enter the paint code.", "iLogic", "") 'no default value
dblSize = InputBox("Enter the size.", "iLogic", 100) 'set default to 100
blGalv = InputRadioBox("Is this thing galvanized?", "Yes", "No", True, "iLogic") 'default is True (yes)
dtDate = InputBox("When was this completed?", "iLogic", Now.ToString("MM/dd/yyyy")) 'set default to today's date
'set custom property values
iProperties.Value("Custom", "Paint Code") = strPaintCode
iProperties.Value("Custom", "Size") = dblSize
iProperties.Value("Custom", "Galvanized") = blGalv
iProperties.Value("Custom", "Completion Date") = dtDate
work really great to find but not to save or created pdf, dxf, dwf, etc,... 😞
It looks fine to me with the code
