------=_NextPart_001_002B_01C34DCB.A8A19F10
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
There are three steps to do this.
1. Create 16x15 bmp files for your icons
2. Name the bmp's.
The name of the bmp should be based on the following rule.
Module name + "." + Sub routine + "." +
.bmp
So if in your default.ivb file you have the following situation: (See =
image)
=20
You would name the bmp file as such:
Got it?
3 Last step. Put your image in the same folder as where your default.ivb =
file is. Normally this is in %/Inventor 7/Bin/Macros/
Tips.
You can make small and large icons for each macro, just change the last =
word in the bmp name to tell which it is. Large icons are 24x24 (I =
think).
Make the background of you bmp files magenta. This will make it =
transparent so that the toolbar shows thru in the right places. I =
developer-speak magenta is the mask color inventor uses. So stay away =
from it in you design and only use it for places you want to be =
transparent.
-Kevin
Content-Type: text/html;
charset=3Diso-8859-1">
There are three steps to do =
this.
1. Create 16x15 bmp files for your=20
icons
2. Name the bmp's.
The name of the bmp
face=3DArial=20
size=3D2>should be based on the following rule.
Module name + "." =
+ Sub routine=20
+ "." + <icon size "Small/Large">.bmp
So if in your default.ivb file you have =
the=20
following situation: (See image)
hspace=3D0=20
src=3D"cid:002501c34e06$54fbbc20$0b01a8c0@dellm530" align=3Dbaseline=20
border=3D0>
You would name the bmp file as =
such:
Got it?
3 Last step. Put your image in the same =
folder as=20
where your default.ivb file is. Normally this is in %/Inventor=20
7/Bin/Macros/
Tips.
You can make small and large icons for =
each macro,=20
just change the last word in the bmp name to tell which it is. Large =
icons are=20
24x24 (I think).
Make the background of you bmp files =
magenta. This=20
will make it transparent so that the toolbar shows thru in the right =
places. I=20
from it in=20
transparent.
-Kevin
------=_NextPart_001_002B_01C34DCB.A8A19F10--
