Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
I-Logic Suppress rule
2 REPLIES 2
389 Views, 2 Replies
I have a query regarding suppressing/unsuppressing ilogic rules.
Let us say, I had created 4 ilogic rules [Rule1, Rule2, Rule3, Rule4]
I had created two LOD's.
One LOD works on Rule 1 and Rule 2
Another LOD works on Rule 3 and Rule 4
Now I have to write a i-Logic in such a way that, if i select First LOD, it has to suppress Rule 3 and Rule 4
Again, if i Select Second LOD, it has to suppress Rule 1 and Rule 2.
Please help me how to do the same.
2 REPLIES 2
rossano_praderi
Hello Mahesh,
with the follow Ilogic code you can suppress/unsuppress the rules.
Try
	ActiveLOD = ThisDoc.Document.ComponentDefinition.RepresentationsManager.activeLevelofDetailRepresentation.Name
	Auto = iLogicVb.Automation
	Select Case ActiveLOD
		Case  "LOD1"
			Auto.GetRule(ThisDoc.Document, "Regola0").IsActive = False
			Auto.GetRule(ThisDoc.Document, "Regola1").IsActive = False
			Auto.GetRule(ThisDoc.Document, "Regola2").IsActive = True
			Auto.GetRule(ThisDoc.Document, "Regola3").IsActive = True
		Case "LOD2"
			Auto.GetRule(ThisDoc.Document, "Regola0").IsActive = True
			Auto.GetRule(ThisDoc.Document, "Regola1").IsActive = True
			Auto.GetRule(ThisDoc.Document, "Regola2").IsActive = False
			Auto.GetRule(ThisDoc.Document, "Regola3").IsActive = False
	End Select
Catch ex As exception
End Try
There is'nt Inventor triggers that react on LOD change.
With ilogics you can write a rule for catching events but, if you don't have a good knowledge on how to do it, you will make Inventor unstable.
The right solution for catching events is to write an addin with Visual Studio.
This is an example on how to make addins with events catching -  LINK.
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
in reply to: rossano_praderi
Thanks a lot
