Is there any way to view all the attributes/properties under 'Design tracking properties' through Inventor GUI?
I can access those properties through API, but I want to check them through GUI.
I tried with Manage->Design Assistan and Design Assistant->Tools->Reports->Properties, but I am not able to view all the design tracking properties that I get through API.
Thanks in advance!
Thanks and Best Regards,
Vaibhav
The Inventor user interface does not provide access to all iProperties. It has a defined list of iProperties that are displayed in the iProperties dialog plus it displays all properties that exist within the user-defined property set which is shown on the "Custom" tab in the iProperties dialog. Any properties added to any other property set besides the user-defined set or any properties sets you create will not be displayed in the user interface.
Hello Brian,
Thanks for the information!
I do observe that that some 'Design tracking prioperties' can be viewed through iProperties dialog.
I am more interested in properties having GUID/UUID values such as Part Revision, Part Type, External Part Revision. These are not seen through the iProperties dialog.
It is seen that 'Part Revision' value changes every time I open Inventor part. Is this expectedbehaviour?
Is there any way this (i.e. change in property value) can be stopped?
Vaibhav Kale,
Senior Software Specialist,
PTC India Ltd.
