Hi ALL,
our group is facing problem in showing the section views of parts
(ex: shafts, splines etc & bearings/circlips etc ) in the assembly drawing.
How to show the sections views in the assy drawings.
Kinldy show me the procedure.
Thanks in advance
Do you want to do this using the API (Macro or Addin) I'm not sure as your question is a bit vague? If not you have posted in the wrong forum. You would have had a faster response in the General Inventor questions forum.
If you want to do so using the API just tell me and I'll have a look for you.
If not and you just want to be able to section Design accelerator components manually then you can either:
Method 1:
* Change selection priority from "Edge Priority" to "Part Priority".
* Select your part to be sectioned.
* Right Click mouse button on the part.
* Select the "Section Participation" expanding menu and change section from "None" to "Section".
Method 2:
* Using the browser tree on the left, Right Click mouse button on the part.
Method 3:
Note: This will section all parts and override the previous methods if used.
* Right Click mouse button of the Section View & Click on View Properties (or just double click on the section view)
* Under the display options tab there is a drop down box that is labelled "Section Standard Parts"
* Change the value from "Obey Browser Settings" to "Always"
Hope this helps.
Regards, Matt
