Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to set dimension display as tolerance?
2 REPLIES 2
CadUser46
329 Views, 2 Replies
In part document setttings where you have the dimensiondisplayenum, how do i set these?  In particaular i want to set to kDimensionDisplayAsTolerance.
Inventor 2010 Certified Professional
Currently using 2023 Pro
2 REPLIES 2
If you look in the Help Files for DimensionDisplayTypeEnum, the only property of this type is Parameters.DimensionDisplayType.
So can access that from PartDocument.ComponentDefinition.Parameters.DimensionDisplayType.
Hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Thanks Philippe. Not sure how i didnt join the dots to get the answer originally.
opartdoc.ComponentDefinition.Parameters.DimensionDisplayType = kDimensionDisplayAsTolerance
