Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to run a rule in a part file from a rule in the drawing file
5 REPLIES 5
1419 Views, 5 Replies
I am trying to use iLogic to help me create the file types I need to give to my vendors once I have created a drawing.
In the .idw file I have a rule that creates a .pdf file and .dwg file. I also want it to activate a rule I have in the .ipt file that creates a .dxf file. Any ideas?
.idw code
trigger = iTrigger0
oType=Left(ThisDoc.FileName(False),3)
GoExcel.Open("S:\DRAWINGS\Folder Types.xlsx", "Sheet1")
For rowPN = 1 To 200
 If (GoExcel.CellValue("A" & rowPN) = oType) Then
    oFile = GoExcel.CellValue("C" & rowPN)
         Exit For
Next
oFolder = "S:\DRAWINGS\NOT RELEASED\" & oFile
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
ThisDoc.Document.SaveAs(oFolder & "\" & ThisDoc.FileName(False) & (".pdf") , True)
ThisDoc.Document.SaveAs(oFolder & "\" & ThisDoc.FileName(False) & (".dwg") , True)
oSM=ThisDoc.PathAndFileName(False)&".ipt"
iLogicVb.RunRule(oSM,"DXF")
MessageBox.Show(oFolder, "File Saved To")
.ipt code
Sub Main
ExportDxf()
End Sub
Public Sub ExportDxf()
         Exit For
Next
    Dim oDoc As PartDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As SheetMetalComponentDefinition
    oCompDef = oDoc.ComponentDefinition
    If oCompDef.HasFlatPattern = False Then
        oCompDef.Unfold
    Else
        oCompDef.FlatPattern.Edit
	sFname = oFolder & "\" & ThisDoc.FileName(False) & ".dxf"
	sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=0&InteriorProfilesLayer=0&InvisibleLayers=IV_UNCONSUMEND_SKETCHES;IV_ALTREP?_BACK;IV_ALTREP_FRONT;IV_ARC_CENTERS;IV_TOOL_CENTE?R_DOWN;IV_TOOL_CENTER;IV_ROLL;IV_TANGENT;IV?_BEND;IV_BEND_DOWN;IV_ROLL_TANGENT;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN&SplineTolerance Double 0.01"
    oCompDef.DataIO.WriteDataToFile( sOut, sFname)
End Sub
5 REPLIES 5
thomaskennedy
This should work for you :
Dim iLogicAuto As Object = iLogicVb.Automation
If (iLogicAuto Is Nothing) Then Exit Sub
Dim doc As Document = ThisDrawing.ModelDocument
Dim ruleName As String = "test"
Dim rule As Object = iLogicAuto.GetRule(doc, ruleName) 'get the rule
Dim i As Integer = iLogicAuto.RunRuleDirect(rule) 'run the rule
That rule will :
- Get the first model document in the drawing
- Defines a rule name (the rule to be fired in the ipt)
- Gets the rule
- Fires the rule.
Hope this helps,
Tom
in reply to: thomaskennedy
Hello Tom,
I tried using that code, it works to pull and run the rule in the .ipt file but I get a error now.
I do not get this error when I run the rule directly from the .ipt file.
Error Message:
Error in rule: Rule1, in document: K550008.ipt
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Any ideas of what is going on? I am not a great programmer and this error is confusing me.
thomaskennedy
Ah OK, try changing this line in your ipt :
to :
oDoc = ThisDoc.Document
ThisDoc.Document gets the document that the rule is in, whereas ThisApplication.ActiveDocument gets the active document, which in this case would've been your drawing document.
Does that work?
Thanks.
That did the trick.
tuliobarata
Would be possible to activate one rule in each part of one assembly that is the base view of th eIDW ?
Like if i put one registry in a part list, and then it runs a rule on each ipt to create a custom property with this registry, is that possible ? My problem here is how to make this link with one specific field of the parts list.
Túlio Barata
IV 2013
