How to replace reference to .bmp-file from .ipt-file?
2 REPLIES 2
620 Views, 2 Replies
I run code from an Inventor addin (implementing Inventor.ApplicationAddInServer in C#). I use Inventor 2010.
My question is about programatically replacing references.
Suppose I have an assembly "keyboard.iam" that references a part "key.ipt"), and that I want to rename "key.ipt" to "001.ipt". Then I can iterate the assembly with Inventor._Document.ReferencedDocumentDescriptors, and call DocumentDescriptor.ReferencedFileDescriptor.ReplaceFile("001.ipt") and it works fine.
But how can I replace a reference to a bitmap file?
Suppose for instance that I have a "key.ipt" with a reference to "pattern.bmp", and I want to rename "pattern.bmp" -> "002.bmp".
If I iterate doc.ReferencedDocumentDescriptors I don't see the bitmap. But if I iterate doc.ReferencedOLEFileDescriptors I can see the reference to the bitmap. So iterating works fine.
But now I would like to rename the bitmap. I don't find a ReplaceFile that I can access via the ReferencedOLEFileDescriptors.
How can I accomplish renaming of a referenced bitmap?
Kind Regards,
Mattias
2 REPLIES 2
Here's how to do that...
Sub ReplaceOLEReference()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
' Get the first ole reference
Dim oRefFile As ReferencedOLEFileDescriptor
Set oRefFile = oDoc.ReferencedOLEFileDescriptors.Item(1)
' Get the corresponding FileDescriptor
Dim oFileDescriptor As FileDescriptor
Set oFileDescriptor =
oDoc.File.ReferencedFileDescriptors.Item(oRefFile.FullFileName)
' Replace reference
oFileDescriptor.ReplaceReference "C:\temp\newimage.bmp"
End Sub
Sanjay-
Hello Sanjay, thanks a lot!
