Hello Folks
Greetings from Kiran
Please find image attached, in this drawing template i am modelled a plate that is having this finish size
Please tell me how write a code in iproperteis Stock string to fetch length, width, thickness parameters
That in to this Raw material & Size box
I think this is what you are looking for:
Otherwise if you want to do it using iLogic you can find attached some example code use to edit some properties of parts in an assembly:
SyntaxEditor Code Snippet
iProperties.Value("Pipe.ipt", "Project", "Description")= Parameter("Part1_MltBdy:1", "NZ1Size") & Chr(34) & " PIPE SCH." & Parameter("Part1_MltBdy:1", "NZ1SCH") ' iProperties.Value("Pipe.ipt", "Custom", "DRAWING_TYPE")= " iProperties.Value("Pipe.ipt", "Custom", "MATGRADE")= "A-106-B (hot finished)"
