Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to link part model values to drawing description using iLogic codes
1 REPLY 1
273 Views, 1 Reply
 Hello Folks
Greetings from Kiran
Please find image attached, in this drawing template i am modelled a plate that is having this finish size
Please tell me how write a code in iproperteis Stock string to fetch length, width, thickness parameters
Tags (2)
1 REPLY 1
RodrigoEiras
I think this is what you are looking for:
https://forums.autodesk.com/autodesk/attachments/autodesk/78/421283/1/Custom%20Parameter%20Formattin...
Otherwise if you want to do it using iLogic you can find attached some example code use to edit some properties of parts in an assembly:
SyntaxEditor Code Snippet
    iProperties.Value("Pipe.ipt", "Project", "Description")=  Parameter("Part1_MltBdy:1", "NZ1Size") & Chr(34) & " PIPE SCH." & Parameter("Part1_MltBdy:1", "NZ1SCH")
'    iProperties.Value("Pipe.ipt", "Custom", "DRAWING_TYPE")=  "
    iProperties.Value("Pipe.ipt", "Custom", "MATGRADE")= "A-106-B (hot finished)"
