How to get Parameter's unit in C#.Net
10 REPLIES 10
Message 1 of 11
2503 Views, 10 Replies
I am trying to get Parameters value and Units using C#.net.
It is working through VBA and .net.But while i am using C#.net, it is showing meassage that "It is not support by the Langauage".
Can any one suggets m eto get Unit fo Patrameter using C#.net.
*********Code
foreach (Parameter oParam in oParams)
// string Str = oParam.Units; //Getting error in this line
Tlist.Add(oParam.Name + "|" + Convert.ToString(oParam.Expression) + "|" +"in");//oParam.Units
Appadurai.G
10 REPLIES 10
Message 2 of 11
rjay75
In C# I've had to use the get_Units() method instead of the Units property. For some reason the units property can never be found.
string units = oParam.get_Units();
Message 3 of 11
rjay75
Message 4 of 11
in reply to: rjay75
Hi Rodney ,
Thanks for your Support.
Appadurai.G
Message 5 of 11
LukeDavenport
in reply to: rjay75
Hi Rodney,
I get a 'member not found' exception at runtime when I use Parameter.get_Units(); in C#
I'm using Inventor 2019.4. Any ideas?
Luke
Message 6 of 11
YuhanZhang
in reply to: LukeDavenport
Hi Luke,
Did you set the reference Autodesk.Inventor.Interop's "Embed Interop Types" to False? Make sure to set this property to False always when you use Inventor API in C#/VB.net, otherwise it may impact some events/methods.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 7 of 11
LukeDavenport
in reply to: YuhanZhang
Thanks for the reply. This didn't solve the problem.
In the end I couldn't get the parameter units using C# despite trying a few different methods, so I had to include some VB code in my C# solution to get the units!
Full solution was as follows:
1) In Visual Studio, create a new VB.net Project (of type Class Library) and add it to the existing C# solution.
2) Add a function to the VB.net class which receives a parameter and returns the unit string.
3) Build the VB.net project.
4) Add a reference to the VB.net project dll to the top of your C# project.
5) Use the VB.net GetParameterUnits function whenever you need.
This worked fine for me.
Hope it helps
Luke
Message 8 of 11
adam.nagy
Did you recompile after setting Embed Interop Types to False?
For me too that got rid of the error.
In addition, you could also use a dynamic variable to access the property using late-binding as your VB project does:
https://modthemachine.typepad.com/my_weblog/2021/02/member-not-found-error-in-c-add-in.html
Adam Nagy
Autodesk Platform Services
Message 9 of 11
oransen
in reply to: rjay75
@rjay75does get_Units still work for you? When I try it (Inventor 2019) it crashes....
Message 10 of 11
Michael.Navara
I had the same issue today. I write the fix for C# users. See my GitHub for more info.
https://github.com/CSmichaelnavara/Inventor-Parameter-Units-Fix
Message 11 of 11
Prashant.Baher
I am converting vb.net code into c# and face this issue.
Changing dll property gives lots of errors so that is "No-Go" for me.
Adam's reply work for me.
Specially this article's final solution of using 'dynamic' object works perfectly.
