Inventor Customization
Distinguished Contributor
mucip
Message 1 of 3 (322 Views)
How to get iproperties of the selected part or sub-assembly using VB.NET
322 Views, 2 Replies
01-19-2013 02:51 PM
I'm using Visual Basic 2010 Express and Inventor 2013...
I can get the properties such as PartName, Description informations of the all sub parts using below code:
 Dim invDocs As Documents
        invDocs = inv_App.Documents
        Dim i As Integer
        Dim invDocument As Document
        For i = 1 To invDocs.Count
            ' Get a specific item from the Documents collection.
            invDocument = invDocs.Item(i)
            invPartNumberProperty = invDocument.PropertySets.Item("Design Tracking Properties").Item("Description")
            MsgBox(invPartNumberProperty.Value)
         Next
Above code works perfect. But I want to get or change iproperty values of the selected part or assembly in the biggest assembly. I got below information:
Dim selSet As SelectSet
selSet = asmDoc.SelectSet
Dim compOcc As ComponentOccurrence
Dim obj As Object
            For Each obj In selSet
                compOcc = obj
                'Debug.Print(compOcc.Name)
                compOcc.Visible = False
            Next
But I do not know how can I get the properties of the selected part or sub-asm . How can I walk from "compOcc" to "invDocument.PropertySets.Item("Design Tracking Properties").Item("Description") "
P.S. I will check the selected part quantity. It must be only ONE! Control Code below:
Dim asmDoc As AssemblyDocument
asmDoc = inv_App.ActiveDocument
        If asmDoc.SelectSet.Count <> 1 Then
            MsgBox("You need to select only one part or sub-asm to change properties...!")
            Return
        End If
Mucip:smileyhappy:
Hello
Try this.
If inv_App.ActiveDocument.SelectSet.Count = 1 Then
If TypeOf inv_App.ActiveDocument.SelectSet.Item(1) Is ComponentOccurrence Then
Dim oOcc As ComponentOccurrence
        oOcc = inv_App.ActiveDocument.SelectSet.Item(1)
Dim oDoc As Document oDoc = oOcc.Definition.Document Dim oProp As Property oProp = oDoc.PropertySets.Item("Design Tracking Properties").Item("Description") MsgBox (oProp.Value) End If End If
krieg
Message 2 of 3 (309 Views)
Re: How to get iproperties of the selected part or sub-assembly using VB.NET
01-20-2013 01:43 AM in reply to: mucip
Hello
Try this.
mucip
Message 3 of 3 (301 Views)
01-20-2013 03:47 AM in reply to: krieg
Dear Krieg,
Thanks... It worked like a charm...
Rgeards,
Mucip:smileyhappy:
