Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to get FileDescriptor from a selectset?
5 REPLIES 5
saseendrankombath
583 Views, 5 Replies
 I want to replace one reference out of multiple reference files used in a part document. How can I convert a selectset.item(1) to a FileDescriptor object.
5 REPLIES 5
May you post more details?
Can you post a sample code?
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
I am able to replace all referenced files if I use the code inside For... Next
For Each oOrgRefFile In oPartDoc.File.ReferencedFileDescriptors
Next
 and a particular one by giving the sequence number of referenced file.
oOrgRefFile = oPartDoc.File.ReferencedFileDescriptors.Item(2)
 for the above I have to modify th code every time to give the sequence number. I want to avoid the same by selecting the required referenced file by selecting from the browser node.
below is the full code I am using
Private Sub Replace_Ref_Part_BtnDef_OnExecute(ByVal Context As Inventor.NameValueMap) Handles btnReplace_Ref_Part_BtnDef.OnExecute
            Try
                Dim oPartDoc As PartDocument
                oPartDoc = m_inventorApplication.ActiveDocument
                Dim oOrgRefFile As Inventor.FileDescriptor
                Dim oOrigRefName As Object
                Dim oNewRefFile As Object = Nothing
                'For Each oOrgRefFile In oPartDoc.File.ReferencedFileDescriptors
                oOrigRefName = oOrgRefFile.FullFileName
                Dim oFileDlg As Inventor.FileDialog = Nothing
                m_inventorApplication.CreateFileDialog(oFileDlg)
                oFileDlg.InitialDirectory = oOrigRefName
                oFileDlg.CancelError = True
                Try
                    oFileDlg.ShowOpen()
                Catch ex As Exception
                    MsgBox(ex.Message)
                End Try
                If oFileDlg.FileName <> "" Then
                    oNewRefFile = oFileDlg.FileName
                End If
                oOrgRefFile.ReplaceReference(oNewRefFile)
                oOrigRefName = ""
                MsgBox("Reference replaced sucessfully with selected File")
                'Next
                MsgBox("Unable to replace the Selected file, Please make sure the replacement file has the same database ID", MsgBoxStyle.Information, "Replace Reference Part")
            End Try
Hi saseendrakombath,
this function read the fullfilename of the first selected item.
Private Sub Replace_Ref_Part()
    Try
        'Dim oOrgRefFile As Inventor.FileDescriptor
        'oOrgRefFile = oPartDoc.File.ReferencedFileDescriptors.Item(2)
        'oOrigRefName = oOrgRefFile.FullFileName
		oOrigRefName = GetSelectedItem()
        Try
            oFileDlg.ShowOpen()
            MsgBox(ex.Message)
        End Try
        End If
        oOrigRefName = ""
        'Next
    End Try
End Sub
Function GetSelectedItem() As String
    doc As Document = ThisApplication.ActiveDocument
    Dim bp As BrowserPane = doc.BrowserPanes.ActivePane
    Dim node As BrowserNode
    For Each node In bp.TopNode.BrowserNodes
        If node.Selected Then
            GetSelectedItem = node.NativeObject.ReferencedFileDescriptor.FullFileName
            Exit Function
        End If
    Next
End Function
Bregs
Rossano Praderi
 nativeobject dosent have any method or property (ReferencedFiledescripter)
the above code returns an error " Object dosen't support this property or method"
I've checked and adapted the code.
Sub Main
	Call Replace_Ref_Part()
End Sub
    Try
	oOrgRefFile = GetSelectedItems
	If oOrgRefFile Is Nothing Then Exit Sub
        ThisApplication.CreateFileDialog(oFileDlg)
        oFileDlg.InitialDirectory = oOrgRefFile.FullFileName
        Try
            oFileDlg.ShowOpen()
            MsgBox(ex.Message)
        End Try
            oOrgRefFile.ReplaceReference(oFileDlg.FileName)
        End If
    End Try
End Sub
Function GetSelectedItems() As Inventor.FileDescriptor
doc = ThisApplication.ActiveDocument
GetSelectedItems = Nothing
bp = doc.BrowserPanes.Item("Model")
			GetSelectedItems = node.NativeObject.ReferencedDocumentDescriptor.ReferencedFileDescriptor
			Exit Function
		End If
	Next
End Function
Anyway, was not my code to give all the errors.
Bregs
Rossano Praderi
