Given the list of AssemblyConstraints how do I list them textually? For example
// error checking removed for brevity CComPtr<AssemblyConstraints> pConstraintList; pAssDef->get_Constraints(&pConstraintList) ; _tprintf_s (_T("The assembly has %d constraints\n"),pConstraintList->Count); const int ikNum = pConstraintList->Count ; for (int iConstraint = 0 ; iConstraint < ikNum ; i++) { CComPtr<AssemblyConstraint> pConstraint; hr = pConstraintList->... what to put here? ... how to print out more data here...? }
How do I get each constraint from the list? And if there is some example of printing out the data that would be good too. I'd need a C++ solution...
Solved by adam.nagy. Go to Solution.
I've managed to get halfway there:
const int ikNumConstraints = pConstraintList->Count ; for (int j = 1 ; j <= ikNumConstraints ; j++) { CComPtr<AssemblyConstraint> pConstraint; hRes = pConstraintList->get_Item(CComVariant(j),&pConstraint) ; if (FAILED(hRes)) { _tprintf_s (_T("Could not get the constraint %d of the assembly, hr=%X\n"),j,hRes); return ; } _tprintf_s (_T("Got constraint %d\n"),j); // details???? }
but how to get textual descriptions of the contraints?
Different constraints have different properties. So once you have the specific constraint then you can collect the information from them. E.g.:
HRESULT hRes; CComQIPtr<AssemblyDocument> pDoc = pInvApp->ActiveDocument; CComPtr<AssemblyConstraints> pConstraintList = pDoc->ComponentDefinition->Constraints; const int ikNumConstraints = pConstraintList->Count ; for (int j = 1 ; j <= ikNumConstraints ; j++) { CComPtr pConstraint; hRes = pConstraintList->get_Item(CComVariant(j),&pConstraint) ; if (FAILED(hRes)) { _tprintf_s (_T("Could not get the constraint %d of the assembly, hr=%X\n"),j,hRes); return NOERROR; } _tprintf_s (_T("Got constraint %d\n"), j); _tprintf_s (_T("Name = %s\n"), (LPCTSTR)pConstraint->Name); CComQIPtr<MateConstraint> pMate = pConstraint; if (pMate != NULL) { // print info } CComQIPtr<AngleConstraint> pAngle = pConstraint; if (pAngle != NULL) { // print info _tprintf_s (_T("Angle = %s\n"), (LPCTSTR)pAngle->Angle->Expression); } }
I hope this helps.
Cheers,
