Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to end running inventor without killing the process
4 REPLIES 4
kbo
564 Views, 4 Replies
I have a vault job that starts inventor and autocad and converts drawings to pdf but the job runs it often fails because inventor isn't closing when the job is done. closing autocad is allways working? Does anyone have the same issues ? and can someone please help with a solution.
Regards Kent boettger
Here is the code i use to start inventor or get a running inventor.
 Try
                INVRUNNING = True
                InvApp = GetObject(, "Inventor.Application") 'System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
                InvApp.SilentOperation = True
                InvApp.Visible = True
            Catch ex As System.Exception
                If InvApp Is Nothing Then
                    INVRUNNING = False
                    Dim inventorApptype As Type = System.Type.GetTypeFromProgID("Inventor.Application")
                    InvApp = System.Activator.CreateInstance(inventorApptype)
                End If
            End Try
here is the code i use to kill the process. i think InvApp.quit() is the right way but this often fails.
 If INVRUNNING = False Then
                    'InvApp.Quit()
                    KILLINVENTOR()
                End If
here is the inventor killer that works. but this can not be the right way to end inventor?
Private Sub KILLINVENTOR()
            Dim pListOfProcesses() As Process
            Dim pInventorProcess As System.Diagnostics.Process
            pListOfProcesses = Process.GetProcessesByName("Inventor")
            For Each pInventorProcess In pListOfProcesses
                If pInventorProcess.ProcessName.ToUpper = "INVENTOR" Then
                    pInventorProcess.Kill()
                End If
            Next
        End Sub
4 REPLIES 4
mslosar
in reply to: kbo
Shot in the dark, but maybe try a save before closing inventor. Seems to me I hit save and then when I hit close it asks me to save again even though I did nothing in between.
Vladimir.Ananyev
in reply to: mslosar
Just an idea:  do you always restore SilentOperation = False  mode,  even in case of some error ?
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
kbo
in reply to: Vladimir.Ananyev
Still no luck! getting inventor to quit without crash or hanging? if i use invapp.quit() only the kill function works.
Here is all the code i use to create a pdf file when a file i released in vault.
The code i run when a drawing is set to state release in vault.
The latest file is downloaded to a local folder and the fullpath of the file is passed to this sub. if the file is an inventor dwg. else it is passed to another sub
that creates the pdf in autocad.
Can somebody please take a look on this issue and help, maybe come upp with a solution.
Regards. Kent boettger.
 Private Sub CreatePdfInventor(ByVal fullfilepath As String)
            Dim INVRUNNING As Boolean = False
            If System.IO.File.Exists(fullfilepath) = True Then
                'Set local *.dwg file attributes else the program will fail
                System.IO.File.SetAttributes(fullfilepath, IO.FileAttributes.Normal)
            End If
            Dim InvApp As Inventor.Application = Nothing
            Try
                INVRUNNING = True
                INVRUNNING = False
                End If
            End Try
            'Dim InvApp As Inventor.Application = GetObject(, "Inventor.Application")
            Dim oNVM As NameValueMap = InvApp.TransientObjects.CreateNameValueMap
            oNVM.Add("DeferUpdates", True)
            Dim oDoc As Inventor.DrawingDocument = InvApp.Documents.OpenWithOptions(fullfilepath, oNVM, True) 'oApp.ActiveDocument
            InvApp.SilentOperation = False
            ' Get the PDF translator Add-In.
            Dim PDFAddIn As TranslatorAddIn
            PDFAddIn = InvApp.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
            Dim oContext As TranslationContext
            oContext = InvApp.TransientObjects.CreateTranslationContext
            oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism 'kFileBrowseIOMechanism
            ' Create a NameValueMap object
            Dim oOptions As NameValueMap
            oOptions = InvApp.TransientObjects.CreateNameValueMap
            ' Create a DataMedium object
            Dim oDataMedium As DataMedium
            oDataMedium = InvApp.TransientObjects.CreateDataMedium
            ' Check whether the translator has 'SaveCopyAs' options
            If PDFAddIn.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
                'Options for drawings...
                oOptions.Value("All_Color_AS_Black") = 1
                oOptions.Value("Remove_Line_Weights") = 1
                'oOptions.Value("Vector_Resolution") = 400
                'oOptions.Value("Sheet_Range") = kPrintAllSheets
                'oOptions.Value("Custom_Begin_Sheet") = 2
                'oOptions.Value("Custom_End_Sheet") = 4
                Dim Pdf_File_Name As String
                Pdf_File_Name = oDoc.FullFileName.Substring(0, oDoc.FullFileName.Length - 4)
                'Set the destination file name
                oDataMedium.FileName = (Pdf_File_Name & ".pdf")
                'Publish document.
                Call PDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
                'Close document without saving
                oDoc.Close(True)
                    'InvApp.Quit()
                    KILLINVENTOR()
                End If
            End If
        End Sub
Vladimir.Ananyev
in reply to: kbo
Similar problem was disscussed here:
http://forums.autodesk.com/t5/inventor-customization/iv2010-vista-64-createobject-createinstance-and...
Look at the following DevBlog as well:
http://adndevblog.typepad.com/manufacturing/2012/06/quitting-inventor-when-quit-doesnt.html
Cheers,
Vladimir Ananyev
