Can any one tell me how to do add-in for inventor 2011 ? .
when i do add-in for inventor 2014 it working fine..
but for inventor 2011 it not loaded properly i think there is some issue.
Solved by YuhanZhang. Go to Solution.
In Inventor 2011 you can also create an Inventor addin with the Inventor Addin Wizard. You can:
1. Install the SDK DeveloperTools.msi(C:\Users\Public\Documents\Autodesk\Inventor 2011\SDK\DeveloperTools.msi) first.
2. Then install the InventorWizards.msi(DeveloperTools\Tools\Wizards\InventorWizards.msi).
3. Now you can in your VS find the addin wizards to create an addin for Inventor 2011.
Hope this helps.
For Inventor 2011 are you registering your addin?
Can you describe more details about your steps? Did you register the addin? Can you see your addin in the Add-In Manager? If yes, is it loaded? Also please attach your addin source code if possible for us to check where the problem is.
Firstly you need to follow the steps below(as I posted it already):
Then launch VS(please note the Inventor 2011 Wizards supports VS2003, 2005 and 2008, or read the DeveloperTools\Tools\Wizards\ReadMe.txt for more details, you should have the VS installed and launched once before install the I
Then compile it the project will automatically register the binary, or you can manually register the binary if you want to move the binary to anywhere else.
Hope this clears.
