Inventor Customization
Distinguished Contributor
6 Kudos
Post 1 of 6
How to determine if an open file is read-only?
435 Views, 5 Replies
07-07-2010 01:26 PM
I'm developing a routine to change file propertites on open files.  The file property changes won't be saved if the file is read-only and the file is read-only if it exists in the Vault but is not checked out.
12 Kudos
Post 2 of 6
Re: How to determine if an open file is read-only?
07-07-2010 09:35 PM in reply to: cadfish1
Try this
Dim File_Attr As String
In Vba/VB6 use
File_Attr = GetAttr("C:\temp\test.ipt")
VB.NET use
File_Attr = System.IO.File.GetAttributes("C:\temp\test.ipt")
If File_Attr = 1 Or File_Attr = 33 Then
Msgbox ("the file is Read only")
End If
René J
6 Kudos
Post 3 of 6
07-08-2010 05:12 AM in reply to: Rene-J
Thanks Rene, this is helpful.  I noticed though that the Document object has a IsModifiable property, what is this used for?
6 Kudos
Post 4 of 6
07-08-2010 05:41 AM in reply to: Rene-J
Correction to your code.  File_Attr should be a number (not a String), I think all Enums are Longs.  Also, your IF test expression only works if read-only is the only attribute set or if read-only and archive are the only two attributes set.  My IF test expression below, returns if read-only is set, no matter what the other Attributes are set to.
Dim File_Attr As Long
If File_Attr And 1 Then
    MsgBox("the file is Read only")
Else
    MsgBox("the file is NOT Read only")
End If
12 Kudos
Post 5 of 6
07-08-2010 06:09 AM in reply to: cadfish1
Hi thanks
The no. 33 If I remember right, if  the inventor file is used in shared project  and set  to reservedforwrite and read-only
René J
6 Kudos
Post 6 of 6
07-08-2010 06:17 AM in reply to: Rene-J
No, 33 is the combining of 1 (read-only) and 32 (archive) file Attribute Enums (long integer).
