Solved by CadUser46. Go to Solution.
Doing it with VBA should be pretty similar to the VB.Net way, except for the icon, where you should use the LoadPicture method:
' Create a standard Microsoft Windows IPictureDisp
Dim idsp1 As IPictureDisp
Set idsp1 = LoadPicture("C:\temp\a.bmp")
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
FYI, I ran into a problem with this a few weeks back.
