How to create a hidden custom property?
11 REPLIES 11
Message 1 of 12
csiddamr
599 Views, 11 Replies
Regards
Reddy
11 REPLIES 11
Message 2 of 12
in reply to: csiddamr
Just look in the Programming Help:
From Inventor:
Help --> Programming Help
Within the Programming Help:
Contents --> Overviews --> Document Properties
Cheers!
T. Ham
Mechanical Engineer
CDS Engineering BV
Dual Pentium XEON 2.2 Ghz
2 GB SDRAM
NVIDIA QUADRO4 700 XGL (Driver = 77.18)
18 GB SEAGATE SCSI Hard Disc
3Com Gigabit NIC
Windows 2000 Professional SP4
Autodesk Inventor Series 9 SP4
Autodesk Inventor Series 10 SP3a
Message 3 of 12
I'm not sure if the overview mentions this, but if you create a property or
a property set with an underscore ("_") prefix in its name, it will be
hidden. Such properties and property sets do not appear in the collections
and the only way to access them is by their name/id.
Sanjay-
"Teun Ham (IV9 SP4 / IV10 SP3a)" nl> wrote in message news:5146831@discussion.autodesk.com...
From Inventor:
Cheers!
T. Ham
Mechanical Engineer
CDS Engineering BV
2 GB SDRAM
3Com Gigabit NIC
Message 4 of 12
csiddamr
I want to create a custom property that should not be visible to the user.
But in the API help mentioned is hiding from the APIs.
If i create a custom property prefix with "_" it is hiding from the API (count will not count this attribute). But it is visible to the user.
What i want is I want to create a custom property that is hidden ( should not be visible ) to the user . Is it possible.
Thanks in Advance,
Reddy
Message 5 of 12
You clearly have not read the Programming Help...
The first example on the 3rd page shows how you can create a new propertyset
with a new property. This property set is NOT visible to the user.
Anyway, see if this helps (no error trapping):
Sub CreateInvisiblePropertySet()
Dim oDoc As Document
Dim oCustomPropertySet As PropertySet
Dim oCustomProperty As Property
Set oDoc = ThisApplication.ActiveDocument
Set oCustomPropertySet = oDoc.PropertySets.Add("MyCustomPropertySet")
Set oCustomProperty = oCustomPropertySet.Add("MyValue", "InvisibleProperty")
End Sub
Sub ShowValueOfHiddenPropertySet()
Set oCustomPropertySet = oDoc.PropertySets.Item("MyCustomPropertySet")
Set oCustomProperty = oCustomPropertySet.Item("InvisibleProperty")
MsgBox oCustomProperty.Value
End Sub
T. Ham
Mechanical Engineer
CDS Engineering BV
2 GB SDRAM
3Com Gigabit NIC
Message 6 of 12
Machado
Hi,Teun?
You code gives a error.
I think that this is an interesting subject, can someone explain this and how to create and edit custom porpertyset.
Thanks.
Message 7 of 12
Not sure what error msg you got, but I guess you have to run createproterty
before find it.
Chris
wrote in message news:5152107@discussion.autodesk.com...
Hi,Teun?
Thanks.
Message 8 of 12
I'm just curious, why you need to hide the property?
wrote in message news:5148282@discussion.autodesk.com...
Thanks in Advance,
Reddy
Message 9 of 12
Machado
HI,Chris!
The error displayed in the Teun code is the following:
Run time error 429
Activex component can´t create object
So what´s wrong here, can someone help on this?
Thanks.
Message 10 of 12
Huh... it's weird ... I did not get that error. Teun's code has 2 subs
1) Run the first sub to add the customer property to the file
2) Run the second sub to show the property that was created in the first sub
You shouldn't run both at the same time 'caused nothing to show !
Other than that, Teun should be the right person to answer your question
Chris
wrote in message news:5152905@discussion.autodesk.com...
HI,Chris!
Run time error 429
Thanks.
Message 11 of 12
Machado
Ok, i've figured out.
I think it was somekind of interference with a add-in.
Thanks a lot.
Message 12 of 12
I am glad you fixed the problem!
Chees,
T. Ham
Mechanical Engineer
CDS Engineering BV
2 GB SDRAM
3Com Gigabit NIC
