When i insert a partlist in a drawing the insert point of the partlist is in the upper right corner? i want the insertpoint in the lower right corner, because i know the height of our titleblock. Then i will allways be able to possition the partlist right above the titleblock. I never know how heigh the partlist is because the amount of parts in the partlist is different every time. does anyone know if its possible to change the partlist insertpoint to the lower right corner of the partlist when its inserted via the API?
Help please.
Solved by jdkriek. Go to Solution.
This will put the Parts List right on top of your title block
Dim oDoc As DrawingDocument = ThisDrawing.Document Dim oSheet As Sheet = oDoc.ActiveSheet Dim oBorder As Border = oSheet.Border Dim oPlacementPoint As Point2d oModelDoc = ThisDrawing.ModelDocument If Not oBorder Is Nothing Then oPlacementPoint = oBorder.RangeBox.MaxPoint Else oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.Height) End If For i = 1 To oSheet.PartsLists.Count oSheet.PartsLists.Item(1).Delete Next i Dim oPartsList As PartsList oPartsList = oSheet.PartsLists.Add(oModelDoc, oPlacementPoint) minXpoint = oSheet.TitleBlock.RangeBox.MinPoint.x minYpoint = oSheet.TitleBlock.RangeBox.MaxPoint.Y maxXpoint = oPlacementPoint.x dPointY = oSheet.PartsLists.Item(1).RangeBox.MinPoint.Y - minYpoint maxYpoint = oPlacementPoint.Y - dPointY Dim newmin, newmax As Point2d newmin = ThisApplication.TransientGeometry.CreatePoint2d(minXpoint, minYpoint) newmax = ThisApplication.TransientGeometry.CreatePoint2d(maxXpoint, maxYpoint) oSheet.PartsLists.Item(1).Delete oPartsList = oSheet.PartsLists.Add(oModelDoc, newmax)
Thanks for this fine / great code example, you saved my day. If you ever come to denmark i will buy you a beer 🙂
i had to modify you code a bit but now it work right like i want i to. Again Thanks!
Here is what i ended up with i had to add the height of my titleblock.
regards Kent boettger
Dim oDrawingView As DrawingView oDrawingView = oSheet.DrawingViews(1) Dim oPlacementpoint As Point2d Dim oPartsList As PartsList Dim oBorder As Border = oSheet.Border If Not oBorder Is Nothing Then oPlacementpoint = oBorder.RangeBox.MaxPoint Else oPlacementpoint = oApp.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.Height) End If 'Delete old partlist if found For i = 1 To oSheet.PartsLists.Count oSheet.PartsLists.Item(1).Delete() Next 'add new partlist and calculate placement oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementpoint) Dim minXpoint As Double = oSheet.TitleBlock.RangeBox.MinPoint.X Dim minYPoint As Double = oSheet.TitleBlock.RangeBox.MinPoint.Y Dim maxXPoint As Double = oPlacementpoint.X Dim dPointY As Double = oSheet.PartsLists.Item(1).RangeBox.MinPoint.Y - minYPoint Dim maxYpoint As Double = (oPlacementpoint.Y + 6.3#) - dPointY Dim newmin, newmax As Point2d newmin = oApp.TransientGeometry.CreatePoint2d(minXpoint, minYPoint) newmax = oApp.TransientGeometry.CreatePoint2d(maxXPoint, maxYpoint) 'Delete the inserted partlist again oSheet.PartsLists.Item(1).Delete() 'Add final partlist. oPartsList = oSheet.PartsLists.Add(oDrawingView, newmax)
on default border working perfect, but on custom border i got error
Error on Line 3 : Type 'p534g9_0' is not defined.
Jonathan can you help?
Thank you
Thank you
MisterZS, I tested with a custom border and it works fine on my end. oSheet.Border contains whatever the active border is custom or not on the sheet. The only thing you could perhaps try is setting the active border before you define oBorder. But that was not needed to work for my tests.
ActiveSheet.Border = "YourCustomBorderName" Dim oBorder As Border = oSheet.Border
I added line of code you suggest but still same error
Error on Line 5 : Type 'p534g9_0' is not defined.
but if i turn off line of code
'Dim oBorder As Border = oSheet.Border it is working but table stick to the sheet size not to the border.
Thank you
I think i found problem. Word Border was in blue and that bother me somehow. I switched to lower case and bingo.
I don't know why.
Dim oBorder As border = oSheet.Border
But here is another question since code working perfect on my machine.
I'm working with multi sheets, and every sheet is with different part. I would like to insert part list table in each sheet with iproperties for that part. I tried with this one and it is always same table in each sheet.
Is this possible?
Thank you
