Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to activate Tab on the Ribbon?
4 REPLIES 4
jursa_martin
3477 Views, 4 Replies
Hi All. How to activate specific Tab on the Ribbon by VB.Net code? Exist any way how to "bring to front" my own Ribbon Tab?
Thanks Martin
4 REPLIES 4
Ralf_Krieg
in reply to: jursa_martin
Hello
It's VBA, but the way is the same.
Sub ChangePanelToToolsTab()
' Get the ribbon associated with the part document
Dim oPartRibbon As Ribbon
Set oPartRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Part")
' Get your own tab
Dim oTab As RibbonTab
Set oTab = oPartRibbon.RibbonTabs.Item("your_own_tab_name")
'activate it
oTab.Active = True
End Sub
R. Krieg
RKW Solutions GmbH
www.rkw-solutions.com
jursa_martin
Hi krieg, thanks for reply, your code working fine. I appreciate your help.
Martin
amitnkukanur
in reply to: Ralf_Krieg
Its not working,
oTab = oPartRibbon.RibbonTabs.Item("Test")
got error on this above line
how to resolve this
Senior Software Engineer
ekinsb
in reply to: amitnkukanur
The name you use to specify the tab in the internal name that was assigned when the tab was created.  This may or may not be the same as the displayed name on the tab.  With the information you've given that's the only thing I can think of that might be wrong.
Brian Ekins
Mod the Machine blog
