Inventor Customization
Active Member
jursa_martin
Message 1 of 5 (1,417 Views)
How to activate Tab on the Ribbon?
1417 Views, 4 Replies
03-31-2010 11:23 PM
Hi All. How to activate specific Tab on the Ribbon by VB.Net code? Exist any way how to "bring to front" my own Ribbon Tab?
Thanks Martin
krieg
Message 2 of 5 (1,417 Views)
Re: How to activate Tab on the Ribbon?
04-01-2010 04:29 AM in reply to: jursa_martin
Hello
It's VBA, but the way is the same.
Sub ChangePanelToToolsTab()
' Get the ribbon associated with the part document
Dim oPartRibbon As Ribbon
Set oPartRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Part")
' Get your own tab
Dim oTab As RibbonTab
Set oTab = oPartRibbon.RibbonTabs.Item("your_own_tab_name")
'activate it
oTab.Active = True
End Sub
Active Member
jursa_martin
Message 3 of 5 (1,417 Views)
04-02-2010 12:57 AM in reply to: jursa_martin
Hi krieg, thanks for reply, your code working fine. I appreciate your help.
Martin
amitk_189
Message 4 of 5 (965 Views)
04-24-2012 11:36 PM in reply to: krieg
Its not working,
oTab = oPartRibbon.RibbonTabs.Item("Test")
got error on this above line
how to resolve this
ADN Support Specialist
ekinsb
Message 5 of 5 (913 Views)
05-09-2012 05:38 PM in reply to: amitk_189
The name you use to specify the tab in the internal name that was assigned when the tab was created.  This may or may not be the same as the displayed name on the tab.  With the information you've given that's the only thing I can think of that might be wrong.
Brian Ekins
Developer Technical Services
Autodesk Developer Network
