I have this ilogic routine
InventorVb.RunMacro("DocumentProject", "Color", "ChangeColor","red")
However I want it to run this macro
Option Explicit
Dim oPartDoc As PartDocument
Dim oCompDef As ComponentDefinition
Public Sub ChangeColor(strColor As String)
Set oPartDoc = ThisApplication.ActiveDocument
Set oCompDef = oPartDoc.ComponentDefinition
Dim appAsset As Asset
Dim oLib As AssetLibrary
Set oLib = ThisApplication.AssetLibraries("Autodesk Appearance Library")
Set appAsset = oLib.AppearanceAssets(strColor)
oPartDoc.ActiveAppearance = appAsset
End Sub
within the part itself.
Ultimately I need to save 3 versions of a file in an assy, each of a different color. So I'm trying to set up a routine that takes the active part, copies an object from the assy to the part, saves 3 copies of different colors, and then creates an assy of each of those 3 parts. I have code to perform almost all of these tasks but I'm stuck trying to bring them together.
My guess is if I can figure out how to run macros on a part from within the Assy I can do the rest.
