In 2012 the Open Drawing was available directly under the marking menus. Now in 2014 it is under the component sub-menu. How can I move it back? See attachment for clarity.
You are showing the marking menu. That is not what I am talking about. For example, when you do it from the browser, you don't see the marking menus at all. Instead you just have the RMC options.
Hi Acadmauto,
Normally, the RMB menu (called linear menu in API) can be customized at
UserInputEvents.OnLinearMarkingMenu( SelectedEntities As ObjectsEnumerator,
SelectionDevice As SelectionDeviceEnum,
LinearMenu As CommandControls,
AdditionalInfo As NameValueMap )
Where, LinearMenu tells the controls. You can add more controls, or remove controls.
So, what I thought is your requirement could be achieved by the code below:
Private Sub inputEvents_OnLinearMarkingMenu(ByVal SelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal LinearMenu As CommandControls, ByVal AdditionalInfo As NameValueMap) ‘remove the control, but get its control definition Dim oContrlDefToMove As ControlDefinition Dim eachCtrl As CommandControl Dim eachSubCtrl As CommandControl For Each eachCtrl In LinearMenu If eachCtrl.DisplayName = "Component" Then For Each eachSubCtrl In eachCtrl.ChildControls If eachSubCtrl.DisplayName = "Open Drawing" Then Set oContrlDefToMove = eachSubCtrl.ControlDefinition eachSubCtrl.Delete End If Next End If Next ‘add the control definition to the location you want to put 'Call LinearMenu.AddButton(oContrlDefToMove, , , LinearMenu.Item(1).InternalName, False) End Sub
but, when I tested, most controls of UI are available in the LinearMenu, but no control for "Open Drawing" 😞 I have not got what happened with the method, but this is the only API way I can think of for your requirement.
