The default line weight for my version is too large in my opinon. So every time I make a new drawing, I have to go to the style ans standard editor, and manually change each individual line weight for each type of line (hidden, text, centerline, ect...) There has got to be a better way!!! Ive gotten a default template made up and changed the style for it, but when I open it up with a new file, inventor gives me an error saying "the style deffinitions in template c:\filename\...dwg, differ from definitions in the sytle library, the style library will be used." So I guess the bigger question is, how do I edit my style library?
Solved by cadmanagershat. Go to Solution.
