Hi
I have a VB code that gets an instance of inventor. It creates a new assembly and then starts adding parts to it. The code works fine and is reliable but I am suprised by how slow the process is.. the process is as follows
'psuedo code...
do
myAssembly.ComponentDefinition.Occurrences.Add(my_component_file, my_position) 'add my next occurrence to the assembly
myOccurrence.Transformation = my_position ' move the occurrence to a new position in assembly space.
With myOccurrence.Definition 'go thru the occurrence and change its dimensions
ForEach p In.Parameters
If p.Name = my_parameter_name Then p.Value = my_parameter_value
Next
EndWith
loop until my_last_component
...I notice that the green progress bar is frequently on with messages in the Inventor statusbar such as "Executing update component" and "Executing change component position".
I wonder is Inventor performing many read/write operations which is causing the slow performance? Perhaps it is updating files after each of my 3 operations in the loop... and if so is there a way i can achieve this faster such as delaying read/write until after all three operations have been performed or until all occurrences have been added??
Any tips appreciated.
Thanks.
Dan
(Belfast, Inventor 2013)
The following VBA code demonstrates some of the ways you can optimize your Inventor plugins:
Sub PerformanceIncrease() Dim Invapp As Inventor.Application Set Invapp = ThisApplication '' Turn off user interaction so that inventor can focus on your API calls exclusively Invapp.UserInterfaceManager.UserInteractionDisabled = True '' Turn off screenupdating to speed up performance Invapp.ScreenUpdating = False '' Set Defer updates to true and force an update when you're finished with your API commands '' This can be done on drawings and sketches as well Invapp.AssemblyOptions.DeferUpdate = True '' Create the document invisible Dim oAssDoc As Inventor.AssemblyDocument Set oAssDoc = Invapp.Documents.Add( _ Inventor.DocumentTypeEnum.kAssemblyDocumentObject, , True) ''Wrap your command into a global transaction so only one undo point is created. Dim oTrans As Inventor.Transaction Set oTrans = Invapp.TransactionManager.StartGlobalTransaction(oAssDoc, _ "My API Calls") '' perform your functions here '' Be sure to end a global transaction when you are finished oTrans.End '' Wrap up Invapp.ScreenUpdating = True Invapp.UserInterfaceManager.UserInteractionDisabled = False '' Make the assembly document visible Call oAssDoc.Views.Add Call oAssDoc.Update Invapp.AssemblyOptions.DeferUpdate = False End Sub
here is one for the books that works for some reason really well in 2022 you dont need to set it to false either.
Imports System.Windows.Forms
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Imports System
AddReference "System.Drawing.dll"
ThisApplication.AssemblyOptions.EnableAssemblyExpress = True
ThisApplication.ScreenUpdating = True
SendKeys.SendWait("{ESC}")
AppActivate(ThisApplication.Caption)
