Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How can i make these custom property formats with VBA?
6 REPLIES 6
Vitornis
761 Views, 6 Replies
6 REPLIES 6
Ralf_Krieg
in reply to: Vitornis
Hello
You can set these formats like this:
Dim oUserParameter As UserParameter
oUserParameter = oInvApp.ActiceDocument.Parameters.UserParameters.Item(1)
oUserParameter.ExposedAsProperty = True
oUserParameter.CustomPropertyFormat.Precision =  CustomPropertyPrecisionEnum.kDegreesAnglePrecision
oUserParameter.CustomPropertyFormat.PropertyType = CustomPropertyTypeEnum.kTextPropertyType
oUserParameter.CustomPropertyFormat.ShowTrailingZeros = True
oUserParameter.CustomPropertyFormat.ShowUnitsString = False
R. Krieg
RKW Solutions GmbH
www.rkw-solutions.com
Vitornis
in reply to: Ralf_Krieg
How do you change the format to fractional?
Ralf_Krieg
Hello
Define the correct type of precision-property
Private Sub fxex()
Dim oInvApp As Application
Set oInvApp = ThisApplication
Set oUserParameter = oInvApp.ActiveDocument.ComponentDefinition.Parameters.UserParameters.Item(1)
oUserParameter.CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
oUserParameter.CustomPropertyFormat.Units = UnitsTypeEnum.kInchLengthUnits
End Sub
R. Krieg
RKW Solutions GmbH
Vitornis
oooo Thanks!
Now i see what i was missing!
What is a good resource for writing these VBA macros?
Ralf_Krieg
Hello
Happy it works. Smiley Happy
The best three sources are:
- Autodesk Inventor programmers help (included in pulldown menu in every inventor installation)
- Internet
- watch window in VBA-Editor to step through the object model tree
R. Krieg
RKW Solutions GmbH
ADNpati
Exactly kreig,
I prefer first and third options.... VBA Help is fantastic and watch window will tell all of the info in referenced Doc.
Cheers
Mechanical Engineer
Inventor Applications Engineer
If my solution seems to remedy your problem, please press the Accept Solution button, Some KUDOS -
