Hello
You can set these formats like this:
Dim oUserParameter As UserParameter oUserParameter = oInvApp.ActiceDocument.Parameters.UserParameters.Item(1) oUserParameter.ExposedAsProperty = True oUserParameter.CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kDegreesAnglePrecision oUserParameter.CustomPropertyFormat.PropertyType = CustomPropertyTypeEnum.kTextPropertyType oUserParameter.CustomPropertyFormat.ShowTrailingZeros = True oUserParameter.CustomPropertyFormat.ShowUnitsString = False
Hello
Define the correct type of precision-property
Private Sub fxex() Dim oInvApp As Application Set oInvApp = ThisApplication Dim oUserParameter As UserParameter Set oUserParameter = oInvApp.ActiveDocument.ComponentDefinition.Parameters.UserParameters.Item(1) oUserParameter.ExposedAsProperty = True oUserParameter.CustomPropertyFormat.PropertyType = CustomPropertyTypeEnum.kTextPropertyType oUserParameter.CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision oUserParameter.CustomPropertyFormat.Units = UnitsTypeEnum.kInchLengthUnits oUserParameter.CustomPropertyFormat.ShowUnitsString = False End Sub
oooo Thanks!
Now i see what i was missing!
What is a good resource for writing these VBA macros?
Hello
Happy it works.
The best three sources are:
- Autodesk Inventor programmers help (included in pulldown menu in every inventor installation)
- Internet
- watch window in VBA-Editor to step through the object model tree
Exactly kreig,
I prefer first and third options.... VBA Help is fantastic and watch window will tell all of the info in referenced Doc.
Cheers
