Highlighting Parts in Sub-Assmeblies
2 REPLIES 2
AB.ViewOnly
558 Views, 2 Replies
Guys,
I'm having a problem highlighting parts within a sub assembly.  A simple structure to demonstarte this issue would be:
TopLevel.iam
        SubAssy.iam
                 ChildPart1.ipt
                 ChildPart2.ipt
Using this structure I wish to highligh ChildPart1.ipt, howver my vba macro code below doesn't seem to work (nothing happens):
    Public Sub Highlight()
        Dim SubAssy As Inventor.AssemblyDocument
        Dim ChildPart1 As Inventor.ComponentOccurrence
        Dim highlightSet As Inventor.highlightSet
        Set SubAssy = ThisApplication.ActiveDocument.ReferencedDocuments(1)
        Set ChildPart1 = SubAssy.ComponentDefinition.Occurrences(1)
        Set highlightSet = SubAssy.CreateHighlightSet()
        highlightSet.Color = ThisApplication.TransientObjects.CreateColor(255, 255, 255)
        highlightSet.Color.Opacity = 0.8
        highlightSet.AddItem ChildPart1
    End Sub
Can anyone provide any help?
Many thanks,
Adrian.
2 REPLIES 2
AB.ViewOnly
in reply to: AB.ViewOnly
Anyone got any ideas?  I still can't seem to get this working, in a nutshell I just want the highlighting to work as it does in the Model browser, when you hover over an item in the model browser it highlights it in the assembly even if its within a sub-assembly...
Again, any help would be greatly appreciated.
AB.ViewOnly
If anyone is interested (or facing the same issue) I've figured out the answer.  You need to add component occurence proxy objects to the highlightset not the sub component occurence objects themselves.  This can be done by first returning the component occurences from the root assembly then returning the suboccurences from those.
e.g.
Dim topHighlightSet As Inventor.highlightSet
    Dim topLevel As Inventor.AssemblyDocument
    Dim subAssy As Inventor.ComponentOccurrence
    Dim childPart1Occurence As Inventor.ComponentOccurrenceProxy
    Set topLevel = ThisApplication.ActiveDocument
    Set subAssy = topLevel.ComponentDefinition.Occurrences.Item(1)
    Set childPart1Occurence = subAssy.SubOccurrences(1)
    Set topHighlightSet = topLevel.CreateHighlightSet()
    topHighlightSet.Color = ThisApplication.TransientObjects.CreateColor(255, 255, 255)
    topHighlightSet.Color.Opacity = 0.8
    topHighlightSet.AddItem childPart1Occurence
End Sub
