Is there any way to hide revision rows when reaching a specific number of rows? I only want to show the 5 latest rows in a drawing, so it would be great if the first rows could be disabled when adding a new row. I know it's possible to split a table when reaching a number of rows, but I would like to hide them instead.
Solved by MjDeck. Go to Solution.
I was hoping to achieve this by maybe by an ilogic rule or a macro, so it happens automatically when adding the sixth revision row. But i don't know if it's possible.
Are you running Inventor 2012? You can do it in 2012, but not in previous revisions.
Here's an iLogic rule to do it. This will work on all revision tables in the drawing.
The rule won't run automatically when you add a row to the table. However, you can at least make it run when the drawing is saved. Use the Event Triggers command (on the Manage -> iLogic tab in the ribbon). Attach the rule to the Before Save Document event.
Dim visibleRowsWanted As Integer = 5 For Each sheet As Sheet In ThisDrawing.Document.Sheets For Each revTable As RevisionTable In sheet.RevisionTables Trace.WriteLine(" --- " & revTable.Title) Dim rows as RevisionTableRows = revTable.RevisionTableRows Dim numberToHide As Integer = rows.Count - visibleRowsWanted If (numberToHide <= 0) Then Continue For For i = 1 To numberToHide rows(i).Visible = False Next Next Next
