Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Help with PDF and folder creation with iLogic
5 REPLIES 5
1341 Views, 5 Replies
I have been reading some posts on these forums regarding automatically exporting PDFs with set names. It has been going okay. I've managed to be able to export PDFs of my Inventor drawings every time I hit 'save'. But a few things aren't working.
1. The code exports the same number of PDFs as there are sheets in my drawing, EXCEPT, every PDF contains the image that is in Sheet 1. So if I have a 5 sheet drawing and export it, all 5 PDFs will depict what is contained in Sheet 1.
2. The code does not create a new folder called 'PDF' to store the PDFs in. Nor does it store the PDFs in that folder if I create it beforehand. I pretty much copied the code exactly from a tutorial I saw on how to do just that, so I'm not sure why it's not working.
Here is my iLogic code. Hopefully someone can help. Thank you. 🙂
 '------start of iLogic-------oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extensionoPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Define the drawing Dim oDrawing As DrawingDocument
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim iSheetNumber As Integer
Dim sheetCount As Integer = ThisDrawing.Document.Sheets.Count
'step through each drawing sheetFor Each oSheet In oDrawing.Sheets
'find the seperator in the sheet name:numberlPos = InStr(oSheet.Name, ":")
'find the number of characters in the sheet namesLen = Len(oSheet.Name)
'find the sheet namesSheetName = Left(oSheet.Name, lPos -1)
'find the sheet numbersSheetNumber = Right(oSheet.Name, sLen -lPos)
'set PDF OptionsIf oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = sSheetNumber
oOptions.Value("Custom_End_Sheet") = sSheetNumber
End If
'get PDF target folder pathoFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
If sheetCount=1 Then
'Set the PDF target file nameoDataMedium.FileName = oPath & "\" & oFileName & "R" & iProperties.Value("Project", "Revision Number") & "" & sSheetName & ".pdf"
End If
If sheetCount>1
'Set the PDF target file nameoDataMedium.FileName = oPath & "\" & oFileName & "-0" & sSheetNumber & "R" & iProperties.Value("Project", "Revision Number") & "" & sSheetName & ".pdf"
End If
'Publish documentoPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Next
'------end of iLogic-------
5 REPLIES 5
rossano_praderi
Hi, this is "your" code with some corrections.
The old code may have created new folders in a different location, try to have a look in your workarea.
Dim oDrawing As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos, rPos,sLen As Long
Dim sSheetNumber As Integer
Dim sheetCount As Integer = oDrawing.Sheets.Count
oFolder = oPath & "\PDF"
End If
End If
If sheetCount = 1 Then
	oDataMedium.FileName = oFolder & "\" & oFileName & "R" & iProperties.Value("Project", "Revision Number") & "" & sSheetName & ".pdf"
ElseIf sheetCount > 1
	oDataMedium.FileName = oFolder & "\" & oFileName & "-0" & sSheetNumber & "R" & iProperties.Value("Project", "Revision Number") & "" & sSheetName & ".pdf"
End If
Next
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
in reply to: rossano_praderi
Hey, thanks!
Another question, if you don't mind. I have my Inventor set up to export the PDFs right before I save, every time I save, but when if I have multiple drawings open and click, "Save All", every PDF that gets exported will have the image of the sheet that was open when I clicked 'Save All'.
Any idea why?
rossano_praderi
I would like to know if you have tried my code?
@Anonymous wrote:
Hey, thanks!
Any idea why?
This could be the solution to yours last question.
In this way the running Ilogic code will be correctly associated with its "Document".
By using yours code on the "ActiveDocument" this will be executed only on this one, you know what i mean.
'Substitute this declaration
'With this
Dim oDocument As inventor._Document = ThisApplication.documents.itembyname(ThisDoc.PathAndFileName(True))
Bregs
Rossano Praderi
That worked!
Thanks a lot, I really appreciate it. 🙂
rossano_praderi
You are welcome.
I would be happy if you accept my solution.
Thank you.
Bregs
Rossano Praderi
