Sorry if this seems simple but I'm really struggling with getting an icon to appear on the button I've defined for the Inventor Ribbon. I'm using Inventor 2014 and Visual Studio VB.NET 2012
The Error I'm getting when launching Inventor is attached (System.ArgumentException.jpg)
I have attached my two .ico's to the project and changed their Build Action to "Embedded Resource"
My code is as follows...
m_PMPWFButton = New PMPWorkFeatureAddIn.PMPWorkFeatureButton()
m_PMPWFButton.CreateButton(m_inventorApplication, False, "PM&P WorkFeature", "Autodesk:CustomCommand:PMPWFButton", CommandTypesEnum.kShapeEditCmdType, m_addInCLSIDString, "Work with Work Features", "Work with Work Features", GetICOResource("WF_ICON16.ico"), GetICOResource("WF_ICON.ico"))
I copied in the procedures as defined at http://adndevblog.typepad.com/manufacturing/2013/07/creating-a-ribbon-item-for-inventor.html
I'm obviously missing something simple.... Help?
Mike
Try the below code, Change the icon name and project nams to your project and icon names. add these procedures to standardaddinserver
Private WithEvents oBtnProjectSketch As Inventor.ButtonDefinition
declare the above and change the button name as you required.
Try : oBtnProjectSketch = CreateButton("Project" & vbCrLf & "Sketch", "IP:IntCmd:ProjectSketch", _ Inventor.CommandTypesEnum.kNonShapeEditCmdType, True, m_AddInCLSIDString, _ "Project Sketch", "Project Sketch - Selected Geometry only", "ProjectedSketch.Proj_Sketch32.png", _ "ProjectedSketch.Proj_Sketch32.png", Inventor.ButtonDisplayEnum.kDisplayTextInLearningMode) : Catch : End Try
define the button, change the names and details as you want.
If firstTime Then Dim partRibbon As Ribbon = m_inventorApplication.UserInterfaceManager.Ribbons("Part") Dim partAddinTab As RibbonTab = partRibbon.RibbonTabs("id_AddInsTab") Dim partRenamePanel As RibbonPanel Try partRenamePanel = partAddinTab.RibbonPanels.Item("id_PanelP_Project_Sketch") Catch ex As Exception partRenamePanel = partAddinTab.RibbonPanels.Add("Sketch Tools", "id_PanelP_Sketch_Tools", m_AddInCLSIDString, , ) End Try Dim partRenameCmdCtrls As CommandControls = partRenamePanel.CommandControls With partRenameCmdCtrls .AddButton(oBtnProjectSketch, True, True, , ) End With End If
use the below function to create button and to convert the icon file
Public Function CreateButton(ByRef strBtnDisplayName As String, ByRef strBtnInternalName As String, ByRef eBtnType As Inventor.CommandTypesEnum, ByRef blnAutoAddToGUI As Boolean, Optional ByRef strBtnClientId As String = "", Optional ByRef strBtnDescription As String = "", Optional ByRef strBtnToolTipText As String = "", Optional ByRef strBtnStdIcon As String = "", Optional ByRef strBtnLrgIcon As String = "", Optional ByRef eBtnDisplayEnum As Inventor.ButtonDisplayEnum = Inventor.ButtonDisplayEnum.kDisplayTextInLearningMode) As Inventor.ButtonDefinition Dim StandardIconIPictureDisp As Object = System.Type.Missing Dim LargeIconIPictureDisp As Object = System.Type.Missing Try If Not strBtnStdIcon Is Nothing Then Dim StandardIconStream As System.IO.Stream = Me.GetType().Assembly.GetManifestResourceStream(strBtnStdIcon) Dim StandardIconImage As System.Drawing.Image = New System.Drawing.Bitmap(StandardIconStream) StandardIconIPictureDisp = ImageToPictureConverter.Convert(StandardIconImage) End If Catch ex As Exception End Try Try If Not strBtnLrgIcon Is Nothing Then Dim LargeIconStream As System.IO.Stream = Me.GetType().Assembly.GetManifestResourceStream(strBtnLrgIcon) Dim LargeIconImage As System.Drawing.Image = New System.Drawing.Bitmap(LargeIconStream) LargeIconIPictureDisp = ImageToPictureConverter.Convert(LargeIconImage) End If Catch End Try CreateButton = m_inventorApplication.CommandManager.ControlDefinitions.AddButtonDefinition(strBtnDisplayName, strBtnInternalName, eBtnType, strBtnClientId, strBtnDescription, strBtnToolTipText, StandardIconIPictureDisp, LargeIconIPictureDisp, eBtnDisplayEnum) If CreateButton Is Nothing Then MsgBox("Failed to create Button:" & strBtnDisplayName) End If End Function #Region "ImageToPictureConverter" Public NotInheritable Class ImageToPictureConverter Inherits System.Windows.Forms.AxHost Private Sub New() MyBase.New(Nothing) End Sub Public Shared Function Convert(ByVal image As System.Drawing.Image) As stdole.IPictureDisp Return CType(System.Windows.Forms.AxHost.GetIPictureDispFromPicture(image), stdole.IPictureDisp) End Function End Class #End Region
Hope the above will help to solve your problem.
