Does Anybody know how to create a circular pattern around the predefined Z axis.
Private Sub createpattern()
Dim oCompdef As ComponentDefinition
Dim oDoc As PartDocument
Dim oSketch As PlanarSketch
Dim oPart As PartFeatures
Dim oProfile As Profile
Dim oExtrusion As ExtrudeFeature
Dim oDef As PartComponentDefinition
Dim objGeometry As TransientGeometry
Set oDoc = ThisApplication.Documents.Add(kPartDocumentObject, , True)
Set oCompdef = oDoc.ComponentDefinition
Set oSketch = oCompdef.Sketches.Add(oCompdef.WorkPlanes.Item(3))
Set objGeometry = ThisApplication.TransientGeometry
Call oSketch.SketchLines.AddAsTwoPointRectangle(objGeometry.CreatePoint2d(1, 1), objGeometry.CreatePoint2d(7, 5))
Set oProfile = oSketch.Profiles.AddForSolid
Set oExtrusion = oCompdef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, 10, kSymmetricExtentDirection, kJoinOperation)
Call oPart.CircularPatternFeatures.Add(oPart.ExtrudeFeatures.Item(1), oDef.WorkAxes.Item(3), True, 3, 360, True)
End Sub
Hi mate,
Here you go...
Cheers
Jon
Dim objCol As ObjectCollection
Set objCol = ThisApplication.TransientObjects.CreateObjectCollection
'Feature to be patterned
objCol.Add oCompdef.Features(1)
oCompdef.Features.CircularPatternFeatures.Add objCol, oCompdef.WorkAxes.Item(3), True, 3, 360, True
End Sub
