Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Help With Creating Circularpattern VBA
2 REPLIES 2
r.hubregsen
577 Views, 2 Replies
Does Anybody know how to create a circular pattern around the predefined Z axis.
Private Sub createpattern()
Dim oCompdef As ComponentDefinition
Dim oDoc As PartDocument
Dim oSketch As PlanarSketch
Dim oPart As PartFeatures
Dim oProfile As Profile
Dim oExtrusion As ExtrudeFeature
Dim oDef As PartComponentDefinition
Dim objGeometry As TransientGeometry
Set oDoc = ThisApplication.Documents.Add(kPartDocumentObject, , True)
Set oCompdef = oDoc.ComponentDefinition
Set oSketch = oCompdef.Sketches.Add(oCompdef.WorkPlanes.Item(3))
Set objGeometry = ThisApplication.TransientGeometry
Call oSketch.SketchLines.AddAsTwoPointRectangle(objGeometry.CreatePoint2d(1, 1), objGeometry.CreatePoint2d(7, 5))
Set oProfile = oSketch.Profiles.AddForSolid
Set oExtrusion = oCompdef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, 10, kSymmetricExtentDirection, kJoinOperation)
Call oPart.CircularPatternFeatures.Add(oPart.ExtrudeFeatures.Item(1), oDef.WorkAxes.Item(3), True, 3, 360, True)
End Sub
2 REPLIES 2
jonbrabbs
in reply to: r.hubregsen
Hi mate,
Here you go...
Cheers
Jon
Dim objCol As ObjectCollection
    Set objCol = ThisApplication.TransientObjects.CreateObjectCollection
'Feature to be patterned
    objCol.Add oCompdef.Features(1)
    oCompdef.Features.CircularPatternFeatures.Add objCol, oCompdef.WorkAxes.Item(3), True, 3, 360, True
End Sub
If this post helps you, please give kudos.
r.hubregsen
in reply to: jonbrabbs
Many thanks for the help Kind Regards Tech2Sea R. Hubregsen Tel: +31 (0)172 748046 [Beschrijving: Beschrijving: Tech2sea logo]
