Hi All.
I've spent all day searching to no avail.
I'm trying to create an add-in with custom button on a custom ribbon panel using a custom .ico. Every example I find shows using iPictureDisp as the type and the LoadPicture() method. I've searched for a com or .net to include for LoadPicture and it appears that it's deprecated, part of vb6 namespace, which I can't find on my system. First of all, I can create the button with text only. Visual Studio's intellisense says the LoadPicture method is "undeclared". I'm surprised I can't find others experiencing this issue as it's also what's suggested in the updated help file.
How are you handling this issue with your add-ins? Finding version specific solutions is a nightmare.
Windows 7 64-bit
Inventor 2013 Professional (Production ultimate suite)
Visual Studio 2010 Express / VB.net
Solved by chipwitch. Go to Solution.
I'm still having some trouble, however, I have managed to get an icon onto a button on a panel through the add-in on a 64-bit OS.
Should anyone else have this problem, create the class in the blog below and compile with your project. Still seems like a lot of work to get a silly picture on a button! Thanks to the author, Philippe Leefsma for providing this solution.
